Essential Hudson Tool...
Thanks, Sam. I now have one in my garage after borrowing one. Will probably use it a few times.
Some one in California sent me one to use when I was aking about them in mid December.0 -
SAM AND EVERY ONE ELSE HERE IS A SITE I PUT UP A FEW YEARS AGO SHOING HOW TO PULL REAR DRUMS WITH A WHEEL PULLER
http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/rearwheelpuller.msnw0 -
SamJ wrote:In case anyone was wondering what an old-fashioned wheel puller looks like...:cool:
LOOKS JUST LIKE THE ONE I HAVE IN SET OF TOOLS. I HAVE HAD IT A LOOONG TIME AS I WAS AN AUTO MECHANIC AND HAVE USED IT ON MOPAR' ASWELLAS MY PACEMAKERS AND ???0 -
Never Use That Puller Unless You Put The Nut Back On, Flush With The End Of The Axle And A Quarter Inch Thick Piece Of Metal Between The Axle And The Puller. This Way You Will Never Ruin The End Of The Axle.0
I used this one from local Autozone. You can rent it for a $20.00 deposit, or in my case I decided to by it. Just don't use the slide hammer it references.
Attachment not found.
Part#27037
-Rich0 -
You can use it on your Jeep truck too.0
Regarding that picture... Where are the jack stands!?! That looks scary.0
how about a factory vibration dampener puller & a steering wheel puller?
ever looked at a factory tool book? neat pics of Hudsons being worked on esp. if have a pre-war one.0 -
hornet53 wrote:Regarding that picture... Where are the jack stands!?! That looks scary.
Good Point. I had to look at the photo again. I guess that Jackstands should also be included in the "essential tools":D0
