Essential Hudson Tool...
SamJ
SamJ Senior Contributor
In case anyone was wondering what an old-fashioned wheel puller looks like...:cool:
  • Thanks, Sam. I now have one in my garage after borrowing one. Will probably use it a few times.
    Some one in California sent me one to use when I was aking about them in mid December.
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    SAM AND EVERY ONE ELSE HERE IS A SITE I PUT UP A FEW YEARS AGO SHOING HOW TO PULL REAR DRUMS WITH A WHEEL PULLER
    http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/rearwheelpuller.msnw
  • J Spencer
    J Spencer Expert Adviser
    LOOKS JUST LIKE THE ONE I HAVE IN SET OF TOOLS. I HAVE HAD IT A LOOONG TIME AS I WAS AN AUTO MECHANIC AND HAVE USED IT ON MOPAR' ASWELLAS MY PACEMAKERS AND ???
  • Never Use That Puller Unless You Put The Nut Back On, Flush With The End Of The Axle And A Quarter Inch Thick Piece Of Metal Between The Axle And The Puller. This Way You Will Never Ruin The End Of The Axle.
  • ratlee2
    ratlee2 Expert Adviser
    I used this one from local Autozone. You can rent it for a $20.00 deposit, or in my case I decided to by it. Just don't use the slide hammer it references.
    Attachment not found.
    Part#27037
    -Rich
  • Uncle Josh
    Uncle Josh Senior Contributor
    You can use it on your Jeep truck too.
  • hornet53
    hornet53 Senior Contributor
    Regarding that picture... Where are the jack stands!?! That looks scary.
  • oldhudsons
    oldhudsons Senior Contributor
    how about a factory vibration dampener puller & a steering wheel puller?
    ever looked at a factory tool book? neat pics of Hudsons being worked on esp. if have a pre-war one.
  • faustmb
    faustmb Senior Contributor
    Good Point. I had to look at the photo again. I guess that Jackstands should also be included in the "essential tools":D
