Fuel Tank "Padding"
Unknown
Greetings from Colorado!
I'm just about ready to put my refurbished fuel tank back in my '51 Hornet. A question. On top of the tank when I pulled it were strips of "padding" that were glued to the raised ribs. What was this material and does anyone know where I can find it? Or, is there a substitute?
Thank you, George T
  • George, I don't know what is was for on your car, but on my 37' T-Plane I used a one inch thick rubber pad to lower my tank to allow the new sending unit to fit. I had a stainless tank produced as my original was beyond repair. It could also be for vibration. Hope this helped.
  • Kind of a linen material. Probably some foam tape would work OK.
  • There is a foil insulation product that would work nicely. Available at www. julianos.com and J.C. Whitney. Works well in floorboards and on the roof to keep the interior somewhat cooler.
  • Do you think that the foam "tape" that they use between the top of the pickup bed and topper would work?
    George T
