Stepdown frame repair
Unknown
For those who have done welding repairs to the frame rails & floors of the stepdowns, what guage steel are you using for these areas? Thanks for any help provided.
Tom Drew
  • bob ward
    bob ward Senior Contributor
    From memory the chassis rails are 1mm/40thou, floors are half of that. But I'd measure it to make sure.
  • rambos_ride
    16 gauge is what I am using for sheet metal repairs and the outer perimeter frame.
    I believe the inner frame rails are 14 gauge - but these rarely need repairs other than spring mounts....
  • Thanks guys for your help!
    Tom
    Tom Drew
    Check out my website.... the following link goes to a sheet on frame repair.
    Note that recenly one of the California HETers bought a frame rail from Vic Z to replace the spring mount area of his frame. Cut and weld in which created a factory quality repair.
    Good Luck
    http://members.aol.com/rcsacimt/Re
  • Thanks, Ken. Really informative and much appreciated.
    Tom
  • Jon B
    Jon B Administrator
    You do know that front floor patch panels are available, right?
  • I believe the inner frame rails are 14 gauge - but these rarely need repairs other than spring mounts....[/QUOTE]
    I can vouch for that !!!
    terry
  • Aaron D. IL
    Gus Souza told me you can take out the rotted rear from by removing the seam sealer and drilling out the pinch welds the factory made then weld a good frame section back into it might want to call him if you get stuck.
  • Thanks Jon, I do know about the floor pans available from Ken Amman. Luckily my rust issues are relatively minor but do require some small areas of metal replacement. I appreciate all of the responses - all that's left to do now is fire up the welder!
  • rambos_ride
    I hate you :mad: - nah - just kidding!
    I wish mine hadn't had the rust issues - of course I bought mine site-unseen on ebay...the #1 thing not to do with a stepdown!
    Of course everytime I see pictures of the prototype Jet convertible I feel really lucky :D
  • No offense taken, Dan. I'll just try to live up to the standards you've set with the sheetmetal work on your '49.
    Tom
