4.6 Ford into 47 Hudson Sedan
Is that the overhead cam engine, like in my '95 Lincoln? Its a great engine, but the electronics would be a nightmare for most of us.0
Some basics I have learned on engine swaps...
Engine and Transmission inclination:
5-6 Degree tilt measured from the centerline of the car.
I know with my Commodore the driveshaft length is an issue. The 49 has a 2pc driveline - but is pretty wimpy by todays standards I was able to use my 2pc donor driveline from a 75 3/4ton GM truck with just the rear shaft needing to be shortened.
This gives me a much beefier driveline and ease of getting replacement carrier bearing parts - something to think about....0 -
Or possibly the Supercharged 4.6 32 valve out of the late model Cobras? Now that would be a sweet conversion with the T-5 trans. Engine compartment probably isn't wide enough for those 4 valve heads though.0
Late model Cobra Mustangs have a T-56 6 speed trans. The T-5 is in the Mustang GT.0
- 174 The Flathead Forum
- 601 Vehicles
