46 PU spring shackle help
I am trying to remove the upper spring shackle sleeve that bolts into the frame. The lower spring shackle sleeves came out just fine from the springs but the upper shackle sleeve on the passenger side refuses to budge. I am considering a comple of things. First is to heat up the frame right around the sleeve and then try and turn it. Second is to get a really good breaker bar/pipe and put some real torque on the sleeve head. I am afraid that if I twist the head off, I will regret the decisions leading up to that action! :mad:
The ends of the frame on the pickups seem to suffer from excessive corrosion and I am wondering if it is just rusted in place.
Any advice?
One other, I believe the sleeve on the driver side loosens to the right (opposite of std). Can someone confirm?
Any advice?
One of the spring shackles is left hand thread, on one end only, ( that is, one thread of the U-shaped shackel is left hand, and the other is right hand) but I can't find any documentation as to which one. The bushing and shackle are both left hand thread, and from memory it is the upper left rear. However it is possible that the one you are trying to remove is actually left hadn thread, so you are trying to screw it in instead of out. Try turning it the opposite way and see how you get on. I don't know why they did this. any clues anyone? Good luck,
Geoff.0 -
Now for a little more detail. Does the upper shackle sleeve (screws into the frame) have the same type of threads on the outside as the one that screws into the curled end of the leaf spring? I have had a 5 foot pipe on my torque bar and it ain't movin'. My next move is to heat up the frame and try and turn it. Any other suggestions?0
Consider inserting a small screwdriver/chisel shaped tool into the end of the spring to slightly enlarge the eye of the spring. You will have to use a knockometer to do so. This will help you to remove the shackle sleeve.0
barrysweet52 wrote:Consider inserting a small screwdriver/chisel shaped tool into the end of the spring to slightly enlarge the eye of the spring. You will have to use a knockometer to do so. This will help you to remove the shackle sleeve.
just for clarifcation, for me, would that be a lefthanded or righthanded knockometer?0 -
I know you won't believe this but I found an AMBIDEXTEROUS Knockometer at a swap meet. It didn't have the instruction sheet with it but I finally figured it out. Works like a charm.
Bob0 -
BJ__TN wrote:
Hey Bob is that the same as a hamulator?I know you won't believe this but I found an AMBIDEXTEROUS Knockometer at a swap meet. It didn't have the instruction sheet with it but I finally figured it out. Works like a charm.
Bob0 -
akcoop wrote:Now for a little more detail. Does the upper shackle sleeve (screws into the frame) have the same type of threads on the outside as the one that screws into the curled end of the leaf spring? I have had a 5 foot pipe on my torque bar and it ain't movin'. My next move is to heat up the frame and try and turn it. Any other suggestions?
Yes, it is the same, just a very lightly indented thread. Have you tried turning it the other way? It may be the left hand threaded one.0
- 184 The Flathead Forum
