Value Of A Twin Carb Setup???
Probably if the carbs are rebuilt and everything is cleaned up and ready to install it's a good price. If it needs rebuilt it sounds high. We bought a couple in the last 2 years and paid 250-300 with manifolds/carb/air cleaners/some linkage. Watch out for cracked exhaust manifolds which is common.
Of course, I don't know what the going price is in Australia or the availability. Carb kits are aboiut $35 for WA-1's0 -
I payed 350 for a set up but it all had to be cleaned up and rebuilt... 500 for a complete set ready to bolt on seems about right. Remember though, the linkege is very hard to find..... very rare to find the linkege unless it's a complete set.....0
i recently payed $400 for my set up, i got lucky and scored a linkege with mine. 51rob, if i were you i would try to talk him done in price a bit. are the carbs rebuilt, is it in good shape? -john0
Agree with everyone here. Complete linkage is not too easy to find. $400 to $500 ish for complete good condition set up. I expect these to go up significantly in the next couple years....0
I don't know if He still has them but Denham Morgan in Kingsport Tn had several sets of Twin H linkages. If you need a set give him a call after 9:30 pm est. at 423-967-3841
Bob0 -
4-5 hudred for a linkage?0
No for everything. However, Twin-H units are getting more scarce and more expensive by the day.0
the only major difficult part of the actual twin h linkage that seems to be hard to find is the main part that gets bolted to the head. The other two shafts can be fairly easily made. I guess a bellcrank is kinda hard to find, but there again, you could make that too...
All of the connectors and what nots can be found at a good hardware store.0 -
Thanks Guy's For All Your Advise. I Will See What Set Up Requires To Run On Vehicle And Report Back...
Thanks Robert-australia0
