51 Fuel Tank Sending Unit?
The Ford truck unit #01A-9275 is what you need. The arm will have to be bent slightly. Works with either 6 or 12 volt. Available from Ford dealers, Dennis Carpenter, most good parts stores, etc. Also available from Stewart-Warner.0
To convert your gauges for 12v, just replace the original instrument voltage regulator (behind the dash cluster) with NAPA/Echlin IR-2. It's listed for the earlier 12v Fords, around '56-62, I think.0
Have replacement fuel senders, at 65.00 work on 6 or 12 volt, add 5.00 shipping ALBRIGHTS VINTAGE COACH, 16593 ARROW BL, FONTANA, CA 923350
- 173 The Flathead Forum
- 599 Vehicles
