Transmisson seal
Unknown
I am going to be putting a od tranny in my jet, the question that I have is will I have any problem getting a rear transmission seal for it? and what type of grease would you guys recommend for it??:confused:
Thanks, Barry Smedley
  • mars55
    mars55 Senior Contributor
    For the rear transmission seal try:
    Al Saffrahn
    32425 W. Nam Vo Rd
    Maricopa, AZ 85239
    520-568-2911
    akhudaz@c2i2.com
    For type of grease 90-80W Gear Oil will work fine.
  • davegnh
    davegnh Expert Adviser
    Have you thought about getting a rear end out of car with Hydra-matic? Might be easier than installing the OD.
  • Jet Tranny Seals Just Came On E Bay, Check It Out, Under New Listings In Hudson, Bill Albright
  • mars55
    Unfortunately, the OD transmission uses a different seal then the standard transmission and it is not clear which trans these seals fit. The good news is that the part number in the Ebay listing, a National 7032S, is still good. It is a NAPA 15005 with a OD 2.3780" and width 0.3130".
  • I have three Jets, ( 2 are parts cars) They are all straight shift If I knew of a hydro rear end that was close to here I might try that. But I don't know of to many Jets in my area.
  • Thanks, Barry
