Transmisson seal
For the rear transmission seal try:
Al Saffrahn
32425 W. Nam Vo Rd
Maricopa, AZ 85239
520-568-2911
akhudaz@c2i2.com
For type of grease 90-80W Gear Oil will work fine.0 -
Have you thought about getting a rear end out of car with Hydra-matic? Might be easier than installing the OD.0
Jet Tranny Seals Just Came On E Bay, Check It Out, Under New Listings In Hudson, Bill Albright0
Unfortunately, the OD transmission uses a different seal then the standard transmission and it is not clear which trans these seals fit. The good news is that the part number in the Ebay listing, a National 7032S, is still good. It is a NAPA 15005 with a OD 2.3780" and width 0.3130".0
I have three Jets, ( 2 are parts cars) They are all straight shift If I knew of a hydro rear end that was close to here I might try that. But I don't know of to many Jets in my area.
Thanks, Barry Smedley0 -
Thanks, Barry0
- 120 Hudson 1916 - 1929
- 612 Vehicles
