262 or 308 ?
drivergo2
drivergo2 Expert Adviser
How can you tell the difference between a 308 and 262 with twin H . It's in a 53 or 54 Super Wasp. Thanks drivergo2:)
  • Geoff
    Geoff Senior Contributor
    The 308 blocks have a reinforcing ridge along the bottom of the crankcase, whereas the 232 and 262 blocks are plain sided.
  • The rib is about 1 inch above the oil pan rail on the left (distributor) side of the block & runs the length of the block. It protrudes about 3/16 of an inch.
  • SCUSE ME, rib is about2 in. above oil pan rail & there's one on each side of the block!
    Visual
    Note the rib on the side of the block... 232 and 262 do not have this rib.
  • Whomever owns that engine needs to replace the original "crankcase breather FILTER" with a tapered, shorty one from K&N; otherwise airborne debris (dust, sand, etc) will get into the crankcase (oil, filter, bearings (cam, rod & main) and serve to destruct the oil rings, & u-name-it).
    The original breather's are basically worthless; I believe this is the primary reason for the oil rings to wear out prematurely, in addition to bearings, timing chain, valve guides & all moving parts.
    On the other hand if you plan on just looking at it and not running it, looks pretty/original.
  • You can go to the K&N website and look it up, knowing the OD of the oil filler tube (based upon my memory, ~ 2").
    http://www.knfilters.com/
    "find air filters by dimension"
    POSSIBLY this one:
    RC-2580
    ~Product Specifications~
    Product Style: Round Tapered Universal Air Filter
    Base Outside Diameter: 3.125 in (79 mm)
    Flange Inside Diameter: 2 in (51 mm)
    Flange Length: 0.625 in (16 mm)
    Flange Type: Centered
    Height: 3 in (76 mm)
    Top Outside Diameter: 2 in (51 mm)
    Top Style: Metal
    Top Material/Finish: Chrome
    Filter Re-Oiling Amount: 0.22 oz (6 ml)
    Flanges: 1
    Inner Wire: No
    Weight: 0.5 lb (0.2 kg)
    Product Box Length: 4.63 in (117 mm)
    Product Box Width: 4.63 in (117 mm)
    Product Box Height: 4.25 in (108 mm)
    You could slide the rubber flange over the tube and add a simple clamp to hold it in place which would require unscrewing it at each removal, plus retightening during reinstallation.
    However, in my case, I put the clamp on the tube just below where I want the filter to rest; filter's a snug fit so it won't go any where.
