New Hudson video on Leno's Garage
[Deleted User]
The restoration of Jay's yellow Hornet is finished. There's a very nice video of Jay showing it off to the 93 year old woman he bought it from. It's a must see!
http://www.jaylenosgarage.com/video/index.shtml?vidID=120108
  • Great Guy And A Great Car. Glad I Supplied Him With The Twin H Manifold, Clock, Transmission And Back Seat And Many Other Small Parts, Bill Albright
  • 50C8DAN
    50C8DAN Senior Contributor
    Note that Jay had Waldron's do the exhaust. I would take that as an endorsement! I sadly used Kepich and wished I didn't!
  • Bernard changed the ball joints?
  • bigboy308
    bigboy308 Expert Adviser
    It looks like the Alternator and the Air Conditioning pump were running with one belt--is that right? I couldn't tell for sure. Has anyone had experience with mounting both on the same side and using only one belt? Thanx.
    Ya, and the rear coils springs as well as all eight spark plugs and the sun roof motor. :rolleyes:
    Jay Leno is quite the decent fellow... and the video is a confimation.
    Actually if you review the tape the alt and compressor are on seperate belts. The folks in the North Texas Hudson Dealers Chapter have figured out how to mount the a small compressor and alternator using one belt to drive these units and the waterpump. Check with John Clements... he just had air put into his S6 Hollywood. Past HET president ... check HET roster for contact information.
  • 464Saloon
    464Saloon Senior Contributor
    I learned when I did my 12v conversion,is that there are a lot of theories out there. I basically followed Park Waldrops instructions. I learned that I did not have to have a voltage drop for the gauges like they showed in this car and Parks instructions. Got that info from Bill A and he was right, they work fine as they are. Starter worked fine as did the horns,which they say you have to change in Leno's video. Park mentioned you had to have a wire and diode running from the ignition switch to the alternator. Supposedly excites the Alt at start up. Only problem is it caused a feedback to the Gen light when the key was off and the light stayed on. So I took the wire out, and it stays off and charges fine. So I can't say why there are different theories out there, I just know what worked on my car and it has been about a year now that way.
  • Il Told You So, Bill Albright
  • Walt-LA
    Walt-LA Senior Contributor
    Park's suggestions are on Ken Cates Stepdown Website under Tips and Resources- pretty far down. Walt-LA
