37 Terraplane coil connection
Gentlemen: here's my situation. I bought a 6v new coil to start my '37 after a very long down period. I rewired the car following the wiring diagram in my shop manual. The coil has the two connections marked + and - in addition to the center high tension lead. Hoping that this question is not too basic, but does the + tap wire go to the ignition switch or to the distributor? Or vice versa, or does it matter? And should the coil get hot?
Thanks!
John T
Thanks!
John T
HI JOHN, lots of opinions on this lately,includeing mine, and some of it inocently wrong. To sort it all out. Coils are made for specificall applications which involve either positive or negative ground. The coil should get WARM not HOT, and yes it does matter as to the voltage delivered to the dist. A simple check is to remove any plug wire and observe the direction the spark travels from the wire to the plug, if you watch closely you will see that it either jumps from plug to wire or from wire to plug, when you have it jumping from wire to plug you have it hooked up correctly and also you will have a slightly longer spark,as the coil has windings that build up energy when properly wired. This is sometimes easyeir to observe at night with no light , same goes for checking for bad wires on an engine that does'nt run just right.0
+ terminal should go to the distributor. Terminal that goes to the distributor should always be the same as the battery terminal that's grounded. ie; Positive post of the battery grounded, pos. term. of the coil goes to dist.0
Now thats a good answer to a simple question.0
Gentlemen, Thanks very much! Super answers to my questions.
John0 -
jtroberg wrote:
John---I hope you replaced your coil with a modern day 6 volt one rather than a N.O.S. as it has been my experience that the N.O.S. ones do not hold up. I would also recommend that you relocate the coil to the passenger compartment in order to give it a cooler environment. It is too hot for it under the hood on the 37s. Factory polarity for your car was positive to ground meaning that the positive terminal on the battery goes to ground therefore requiring the positive side of the coil wire to also go to ground. Cliff MinardGentlemen: here's my situation. I bought a 6v new coil to start my '37 after a very long down period. I rewired the car following the wiring diagram in my shop manual. The coil has the two connections marked + and - in addition to the center high tension lead. Hoping that this question is not too basic, but does the + tap wire go to the ignition switch or to the distributor? Or vice versa, or does it matter? And should the coil get hot?
Thanks!
John T0 -
Clif, Thanks for the reply. I do have a modern NAPA coil rather than a NOS. I had not thought about moving the coil into the passenger compartment, but if it will help improve the reliability of the car I will try it!
John0 -
What part number is the napa coil for 6 volt Terraplane?0
Chuck G wrote:What part number is the napa coil for 6 volt Terraplane?
Speaking of coils ????? What are or are there any secondary voltage-current changes in a coil 6 or 12 volt ? I know there are high out put coils like Accell racing coils etc. But if I have a certain part # and its 6 volt and all car makers use the same size are they different secondary wise ? Can I use a 6 volt V.W. coil in my 29 Hudson (Same Size) and have the same resaults ?0 -
not an expert by any means but, It is my understanding that 12v coils all have a resistor incorperated in the system somewhere, either internal or external, reduceing them to 6v primary input If one wanted to know in depth about coils, type in ignition coils in your browser and you can spend the next week or so confuseing yourself. For you guys that are "hotrodding" your engines find the one from HOTROD MAGAZINE, it gets down to some real nitty-gritty on fine tuneing your engine for specific results. For us old geezers that just go for a leiserly drive it seems that anything more than a reputeablle brand stock coil is not needed, then again ,that HotRod article has some good advice for low rpm {under 3000} users Coils: 6v from any car will work on any other 6v car,pick the one with the highest OUTPUT and the parts guy won't know, 12v come with internal resister or W/O and require an ext resister call my grandson when your done sifting that stuff on the net,I'll be driveing my GOLDEN HUDSON > LOOK FOR THE BLUE SPARK< THEN YOU GOT IT RIGHT0
'37 Terraplane tune-up parts.
Dist. Cap: Standard Motor Parts AL-92 NAPA AL59
Ign. Coil: Standard Motor Parts UC-14X NAPA IC7
Points: Standard Motor Parts AL-5661X NAPA CS709
Condenser: Standard Motor Parts AL-111 NAPA AL869
Rotor: Standard Motor Parts AL-102 NAPA AL32
Spark plug: Autolite 295.0 -
Thanks mars, I wrote all of the parts down you listed. I had some but now i know what to look for when i go to a parts store or a swapmeet.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
