Windshield Sealer
Unknown
What is the best sealer to use for new windshield glass and rubber on a
1936 Terraplane. I would like something that does not set up very fast
because I work too slow.
  • rambos_ride
    Do not use urethane sealer or silicone. Silicone is just a big NO-NO and urethane will harden and is made non-rubber seal installed windows on modern cars.
    This is the product and part # you want and should be available at a local autobody supply or online.
    3Mâ„¢ Auto Bedding and Glazing Compound, 08509
    Non-hardening, pliable, water-resistant, medium-bodied sealer for sealing auto seams and between windshield rubber and car body. Can be used as a supplementary sealer for auto glass installation.
  • YOU DO NOT NEED SEALER ON THE REAR AND QUARTER WINDOWS. k gap rubber does the job, front windshields also on 37s. stepdoowns another matter as they just push up against inner body, i use a clear sealer as desribed, wipe off the excess, BILL ALBRIGHT
  • Bill,what is the clear sealer you referred to? The windshield is my only concern
    on my 36 pickup. Thanks for your input. Howard
  • Rambo, Thanks for your reply. Howard
