Where To Get A 7x
Unknown
I AM LOOKING FOR A 7X. I WILL PAY WITHIN REASON, ANY PART FOR 7X WANTED AS WELL
  • DAVE SOLLEN HAD A SPLIT EXHAUST MANIFOLD FOR SALE BEFORE THE HET NATIONALS, NOT SURE IF HE STILL HAS IT, DROP HIM A PM, HE'S DAVE S.
  • have a fresh rebuilt 7x in a 51 Pacemaker 2 dr brougham, with single lever OD and new paint, chrome and a great interior drive it home for 17,500. BILL ALBRIGHTS VINTAGE COACH, FONTANA, CA 92335
  • hdsn49
    hdsn49 Senior Contributor
    Check the following link:
    http://www.uncommonengineering.com/
  • russmaas
    russmaas Senior Contributor
    He said within reason
  • I recommend that you get it in writing (BEFORE WORK BEGINS) from any engine builder who CLAIMS to know Hudson engines, that:
    1) the engine will not leak oil from the front seal, nor the rear seal or he will pull the engine, as necessary, and repair any leak - any/all leaks within the first 1000 miles. Get evidence, before the engine is built, that the crankshaft sleeve that the rubber seal (timing chain cover seal) rides on is NEW.
    2) that the ENTIRE rotating engine assembly (not just the crankshaft) will be dynamically-balanced by a reputable machine shop, and proof of that balancing in writing will be provided to the customer before the engine is reassembled. If he try's to talk you out of it he is trying to cheat you and put more money in his pocket.
    3) get documented evidence that the engine will have a true 7X camshaft
    4) get documented evidence that the port work is correctly done
    5) get evidence that the engine will have a tru-roller timing chain
    6) that ALL engine parts are cleaned in a vat (list each part (include the oil pickup tube and screen PLUS the access-covers to adjust valves) & have him sign the contract before the work begins)
    7) drill and tap for 1/2" head bolts (grade 8)
    8) you fill in all the other things in the contract that you want and demand (detail, detail, detail.........lving no loopholes for him to wiggle out); have your lawyer review/edit it before the contract is signed in the presence of your lawyer. Do it once and do it right!! =^..^=
    $7K PLUS is a lot of money to spend and not get what you pay for; been there, done that.
    .....as a gentleman from Mesa, AZ told me once,
    "The world is full of crooks!", and I tend to believe him.
  • SamJ
    SamJ Senior Contributor
    Remember that the "7X" can be approximated, but not duplicated unless you have a factory 7X block, and they are very rare. :cool:
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    Hi Dave Sollon Does Have A 7x Split Exhaust Manafold It Is At My House He Didnn't Sell It At The Natiopnal Meet It Is $400 + Shipping Contact Dave I Just Halled It Home For Him
