1935 Terraplane Special Shocks
35 Terraplane
I have a 1935 Terraplane Special. It has a blown passenger side front shock. Does anyone have a source for replacements?
If they are tube shocks, take one to a parts store and see if they can match the length and bore where it slides on. Some times I've had to grind down the center tube or add spacer washers to get a good fit.0
I just replaced all the shocks on my '39.
I put airshocks [Toyota Landcruiser] on the back, perfect fit, plus I can alter ride height easily if required.
For the front, I found same size adjustable oil shocks at a shock shop and we just had to cut the top pins off and weld some eyes in. Job done. Goodluck. Paul.0
