sheet metal piece needed
Not sure that he has it but try Lance Walker, AKA, HUDZILLA He's in the roster and posts here quite often.
Bob0 -
I got a set from Ken Amman. He has more. He is listed in the WTN.0
You mean the fender extension? If it's the same as a '51, I prolly have one. Where are you located?0
i need to make sure that it has a rectangle cut out and not a square cut out fotr the park light assembly to fit in to and a spot above to hold the lower grill pice that sits on it, thanks guys...lisa g0
- 184 The Flathead Forum
