sheet metal piece needed
Unknown
Hi All, I need a passenger side lower front fender piece that holds the park light assembly for my 49 super, it needs to be for a long wheel based car. Any help is appreciated.
Hudsonly, Lisa G
  • Not sure that he has it but try Lance Walker, AKA, HUDZILLA He's in the roster and posts here quite often.
    Bob
  • I got a set from Ken Amman. He has more. He is listed in the WTN.
  • dwardo99
    dwardo99 Expert Adviser
    You mean the fender extension? If it's the same as a '51, I prolly have one. Where are you located?
  • i need to make sure that it has a rectangle cut out and not a square cut out fotr the park light assembly to fit in to and a spot above to hold the lower grill pice that sits on it, thanks guys...lisa g
