id 1933 terraplane
i have what everything i saw is a 1933 hudson terraplane.can anyone help about where a ser# would be on the body also i think the frame is also hudson is there any # or id way to id the frame,also i would like to find some parts for it (rumble seat hinges,radiator grill/shrawd,and mics other)
I believe you will find it stamped on the right front of the front axle.
I too have a '33 Essex-Terraplane, an 8.0 -
i dont think its the orig front end (think its ford)any hidden #s on body or frame, can you send me some pics of yours oldhudsons0
Isn't the serial number on a plate on the firewall, engine side, passenger side??
In any event, 1933 serial numbers run:
K - Standard Six - 364125 to 372899
KU - Special Six - 5001 to 21495
KT - Eight - 65001 to 78250
Alex Burr
HudsonTech
Memphis, TN
http://www.freewebs.com/hudsontech/index.htm0 -
the orig floor and firewall is gone any other ideas0
33 terraplane wrote:the orig floor and firewall is gone any other ideas
Maybe somewhere on the rear axle, or possibly on the right side of the frame near the back somewhere, if you can get to it.
Alex Burr0 -
are you saying pass rear of frame?0
Try looking on the rear axle housing, passenger side (at least, in the U.S.!) at the top side. You will want to wire-brush the rust off. It is stamped in to the housing. At least that is where Hudson stamped it on later 1930's Hudsons.
If you were asking for photos of 1933's in general, you can go to the Hudson club's website at http://www.hudsonclub.org/ and click on OTHER LINKS, to see a number of pages which contain various Hudson photos. John King's has an extensive collection of Hudsons at car shows, and Alex Burr's has a huge number of original Hudson factory photos (plus more modern photos of club members' cars).0 -
Take a look at my avatar. Mine is a Terraplane 8 rumble seat coupe. Your serial # is or should be stamped on the right frame rail, just rear of where the original brake cable went thru. Yours looks to be a short wheelbase 6. Makes a neat highboy0
- 184 The Flathead Forum
