36 Terraplane Question
Unknown
Can anyone tell me where the ground strap location is for the engine/frame is on a 36 Terraplane? I have the battery ground, but I believe that there is a chassis ground also. When I took this thing a part it either did not have one, or I didn't take note of it. I would like to have it where the factory put it, or I can figure out a place.
My worst fear is to take this to the Nationals (if I ever get this done) and have the ' Ground Strap Inspectors' ask me to leave for non compliance:eek: .
  • timbersmith
    timbersmith Senior Contributor
    I'm no expert by any stretch of the imagination, but I'm pretty sure I know where [at least one of] the ground is. In this case, it was between the rear underside of the transmission and the crossmember - a collection of copper straps, basically (4 or 5, 'bout 1" wide and 18 gauge). They weren't that long, maybe 6" at the most.
    I can see about snapping some pics if you'd like. I had just cut the straps when I pulled the engine/trans, and I do still have the section of frame as well. Might take a couple days, though.
    - Mike
  • Jon B
    Jon B Administrator
    Fear not. Our last Ground Strap Inspector was escorted out of town on a rail several Nationals ago, reeking of tar and shedding feathers left and right...
  • Jon,
    I'm glad to see that they finally ran that rascal out of town, now if I can just get past the" The Original Air in the Tire Gang" I can breath easy!
    Timbersmith,
    Pictures would be great.
  • Uncle Josh
    Uncle Josh Senior Contributor
    Timbersmith is right. I just hooked one up on the 37 Doodlebug.. Bolts from the lower right bell housing bolt to a hole in the cross member. Original was multiple copper straps or use woven ground strap available at your local tractor supply. Make sure it's bright n'tight.
  • timbersmith
    Well, here's what I've got. The first pic is the front-side of the crossmember mount, the second pic is the back of the crossmember mount, and the third is the mount on the bellhousing.
    The straps are a hair less than 1" wide (say 15/16" - 31/32"), and they measure out to about 26 gauge -- or 12 oz copper. I had cut through 7 strips, but it looks like there might have been 8 total. I didn't check length, but I would guesstimate it at 7", max 8" long. The straps mount to the crossmember with what looks like a 1" x 5/16" bolt (1/2" head) and nut, and it mounts to the lowest right-hand-side bolt on the bellhousing.
    Ya know, it never crossed my mind to save the ground strap. Only really noticed it when I was pulling the engine and the frame remains were following.
    - Mike
  • Thanks Timbersmith,
    I didn't save mine either, but your pictures will be a big help.
