more p/u progress
I'm going to put a couple of your photos on my Hudson web site ( http://groups.msn.com/HudsonMotorCarCompany/ ) under "Hudsons Under Restoration." Would appreciate you sending me an email with some general info, your name, state, etc to put with the photos.
Hudsonly
Alex Burr
hester_nec@yahoo.com (there's an _ between hester and nec).0 -
making great progress, ooks mighty fine, when you get to interior. i have nos wiper switches, wiper arms and blades, glove box inserts, and glove box instrument and clock face.bill albright. ALBRIGHTHUDSONS@MSN.COM0
Looking good. You have made lots of progress from the first pic. I'm about ready to put all of the parts of my truck back on my frame to check the fit before paint. Have some of the pics in the Hudson Essex Terraplane MSN group, but I need to add some more.
Best regards,
Lance0 -
I'll be painting it with a buddy of mine, he'll probably do the actual topcoat shooting. Its going to be suede black with some red and orange accent striping. I also plan on dropping it 2 inches.
I drove the truck to work today, man is it low geared, top speed looks to be about 50mph. How difficult is it to find/install an overdrive trans?0 -
Shouldn't be hard at all once you locate one. The truck was identical with the car, mechanically, and OD's were common on the cars. If you take the OD off a junker, be sure to get the shorter drive shaft to match, though...or you'll have to have your drive shaft shortened. I believe that OD's up through 1952 will work (with a possible bellhousing modification). Check the WTN ads for OD's, or contact Al Saffrahn in Arizona, he might have one for sale. You probably have one of the stump-puller ratio gears, at very least you could obtain a 4.11 which was pretty much standard in the passenger cars (and you can sometimes find NOS gearsets for sale).0
I was thinking of possibly replacing the rear end with one that I have out of a Javelin (3.08 gears), does anyone know what the rear track is on the pickup?0
stock rear end should be 4.11 ratio. o/d vehicles usually had 4.56 ratio.0
Most rear ends on the trucks were 4.56 It would have been easy to get a 4.11 however, since it was the same rear axle w/the 11in brakes used on the Commadore Eights.
I put a tranny/OD from a '49 in my 46. Fits great, and the governor misses the X-frame by about 3/4 inch. Must use the earlier bell housing with the later tranny.
Larry, HET truck guru0 -
Rear tread all models 41-47 is 59 1/2in
Front is 56 1/40
- 111 Hudson 1916 - 1929
