speedometer gear needed
dave s wrote:I need an 18 tooth driven gear for a dual lever standard o/d transmission. Any suggestions or help out there? Thanks.
Dave S.
Dave
The following URL is to a Studebaker site Trans parts T90 and T86, the later being the model of the double lever trans... fellow has 18 tooth Speedo Pinion Gear listed for $30.
Could this be what you are looking for?
http://www.genuinestudebaker.com/cats/studebaker_transmission/ring_gears_rel.htm
Cheers0 -
Thanks, Ken.
I emailed them and asked. Mine is short gear that is 1 7/8" in length.0 -
The gear they have is not right one for Hudson. A man sent me an early one, and said it would fit, but it can not be transfered to small shaft. I returned it to him. The one I need has smaller hole for smaller diameter shaft.0
dave s wrote:I need an 18 tooth driven gear for a dual lever standard o/d transmission. Any suggestions or help out there? ( It is the shorter one, 1 7/8" length )Thanks.
Dave S.
Dave s, I bought one from Doug Wildrick for my 49. Works great. Richie.0 -
Thanks, but 49 takes the longer shaft, I need short shaft. I asked Doug at National and he doesn't think he had any.0
Try Lester Harris at (775) 267-2559. Saw at lot at his wherehouse today. Maybe he has the right one for you.0
For anyone else needing one, I purchased an 18 tooth from Studebaker supplier, StudebakerParts.com and it is right for 54 transmission. Thanks to Ken Kates for suggesting Studebaker.0
For what it's worth, Nash also used the Warner T 86 trans along with some Ford products 57 and up0
- 175 The Flathead Forum
- 602 Vehicles
