Carb. I.D.
Unknown
I have a Carter carb. and would like to know if and what Hudson it would be correct for. Casting # 286. Tag # 505 SA. Metering rod - 75-638. Thanks. Norm:confused:
  • Your tag number does not match up but your casting number matches a 1941- 1947 3x5 engine. I hope this helps Chuck G.
  • hudsontech
    hudsontech Senior Contributor
    Casting number is for carburetor WDO-461S used on Models 41, 43 after serial number 3116 (1940 Six Cyl), 1941 before S/N 2140 and Models 10, 18, 20 and 28 with 212 engine.
    Metering rods (2) for the 461 Carb were:
    Standard - 75-404
    1 size lean - 75-414
    2 sizes lean - 75-415
    3 sizes lean - 75-416
    I have most carburetor sheets 1935-1941 and 1948-1954 - the metering rod you listed is not shown on any of them. If I find the info, will post later.
    Alex Burr
    HudsonTech
    Memphis, TN
  • hudsontech
    Just ran a google search on "Carter 505-SA" - hit gave me 1937-1940 Oldmobile 8 cylinder.
    Alex Burr
    HudsonTech
    Memphis, TN
  • Alex
    thanks for the info. i will have to remember to use Google search. I just have a list of Hudson carbs and year they fit. It helps but not as much as your info.
    Thanks Chuck G.
