water pump lubricant
40-47 Hudson water pumps have zerks ?..... stepdown's don't....0
Grease is like oil, a lot has changed since 1947, all for the better. I simply use a good quality multipurpose grease for about everything except wheel bearings,and where electrical grease is called for, whether it's a newer peice of eguipement or an old one0
Try grease they use for marine uses.Available from any marine outlet.0
I've been using marine grease (blue) in my 1953 Nash for years. I think it works well. I have had a couple of water pumps go out (leak), but I do not think it was because of the marine grease.0
Forgot to mention that you can purchase the grease at just about any auto parts store.0
Super46 wrote:What lubricant should be used in Hudson water pumps with grease zerts (ie 40-47)? The manual calls for an aluminum soap lubricant. What's that??
Thanks
Steve0
- 175 The Flathead Forum
- 602 Vehicles
