Progress on the 47 "Roll Cage"
This was my first attempt at building a roll cage and I feel pretty good about it. There are no kits that fit a 47 Hudson so Dad and I bent and notched all the bars, its a true custom install. I never realized how short my doors were until we started this project. I think I could have ordered a cage for an S-10 truck and it fit! There are a couple of changes I would make the next time but I think it will do for an old drag car.
http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/hudsonspeedparts.msnw?Page=Last
I have the least idea what you have designed. I have built and raced several sprint cars and safety was allways on my mind. Had my share of bumps, and 3-4 really bad ones , destroyed a couple of cars but never had the roll cage fail even doing barrel rolls on a concrete wall. Things you need to consider. Gussets add a great deal of strength at all weld points. X's between larger areas is a must. Remember this , Sideways the bars have little strength, they will bend from the force of a crash, so you must consider where the impact is likely to come from both fore and aft and side to side and have end to end bar resistance to avoid cage collapse. I hope you used chrome molly or at least service steel as material . Black pipe is far too soft. Bud0
The car is for Drag Racing and the design is for a 8.50+ sec. chassis cert. The design is straight out of the NHRA and SFI rule book. The cage is constructed from 1.675" X .134 mild steel tubing as per NHRA rules. If this were for round track racing yes there would be a lot more bars.0
Progress really looks good. I have cut out the X frame in my '41. Nice job on the front end. Hope to do that to mine next year. What class are you going to run. I'd love to see a hudson in super gas.
Randy0 -
I'd like to be able to do some roll-cage work on the 49 custom, what did you use to make the bends and notch the ends of the tubes?
Thanks
Dan0 -
Looks real good to me and you did do a nice job yourselfs. I measured mine then bought the tubing at a local Stock car Speed Shop where they did all the bends. Might be a suggestion for others.....
Chuck0 -
rambos_ride wrote:I'd like to be able to do some roll-cage work on the 49 custom, what did you use to make the bends and notch the ends of the tubes?
Thanks
Dan
Dan, I bought a copy of the JD2 style manual bender and it works great! It makes very nice bends. The notcher is a standard unit from Eastwood mounted to the wall and using a very old B&D 1/2" drill. It also worked very well, partially because of the high torque/low speed drill.
Randy
Randy, Thanks the car will be run in Pro/Footbrake and hopefully some Nostalgia Gas races. I don't plan to run the electronics you need to run any of the "super" classes. I would like to though!0 -
They have cheap hydraulic pipe benders with saddles and electric powered notchers at Harbor freight. Never used any of theirs. Anyone have experience?0
hudsondad wrote:They have cheap hydraulic pipe benders with saddles and electric powered notchers at Harbor freight. Never used any of theirs. Anyone have experience?
I have had the HF bender for about 12 years now, it has built a few dirt trackers with no problems if used properly.
AS for the notcher I don't own one but a friend of mine does, he builds 2 or 3 cars for sale every year and loves his.0 -
What motor and trans do you plan on using?
Randy0 -
maasfh wrote:What motor and trans do you plan on using?
Randy
The first engine will be a 440 with a 727 trans. should be good for low 11.s to high 10.s in the 1/4 Eventually 500" Wedge and mid 9's:eek:0
- 101 Essex Super 6
- 612 Vehicles
