Centerpoint Steerig Fix?
Gert Christianson Of Salt Lake City Has The Teflon Bushings Which Work Well, Randy Maas Has The Orig Type Bearings And Repro Pins, Bill Albright0
Thanks, Bill0
At almost any bearing supply house Torrington BH 1616 these are a tad longer than the stock ones that Hudson supplied, but do work. I believe the stock length ones are Torrington BH 1612. As always put the seal end part of the bearing assembly towards the outside, away from the grease fitting. Also if you need to shim the centerpoint, VW bug generator/alternator pulley shims will work with a small enlargement of the center hole. Happy Trails Lou Cote
There was a WTN article about fixing the centerpoint steering and evidently with the info from Lou Cote there are several alternatives. If you want more info on the bushing I supply please email me, Gert Kristiansen, at:
HETgtokristi@networld.com Remove the HET prefix, thanks, Gert.0
- 114 Hudson 1916 - 1929
