54 Hornet parts
I am restoring a 54 Hornet Hollywood and need the following parts
1 good used backup light lens
good ivory steering wheel
good used Hollywood emblem for drivers side front fender
good used TwIN H POWER emblem for trunklid
good used ivory signallight switch knob
good used Bendix Treadle Vac master cylinder not pitted
where piston rod seal sits. Thanks Hudsonky duncan
duncan wrote:I am restoring a 54 Hornet Hollywood and need the following parts
try clicking on the KGAP link in my signature here. they can help you witha few of these items, I think the backup lenses, hollywood emblems, twin H power emblem, ivory turn signal knob. Not surem, give their site a chance.0 -
I have a set of Hollywood script, both are good and have the mounting pins in tact. The driver's side is better with some small pits, but will shine up, probably needs to be rechromed. The passenger side is pitted and doesn't shine, needs rechroming. They are a good set that needs rechroming. I have pictures which were too large to post here, if you supply your e-mail I will send the pictures.0
Duncan,
here is your steering wheel on Ebay
http://cgi.ebay.com/ebaymotors/1954-Hudson-Super-Wasp-Steering-Wheel-Horn-Ring-Button_W0QQcmdZViewItemQQcategoryZ140729QQihZ015QQitemZ250261389764QQrdZ1QQsspagenameZWDVW0
