Jet brake hardware & spring kit part number
I have some extra brake hardware.
Barry Smedley
53' Super jet
and a bunch of Crosley's0 -
Here are some part numbers. These numbers are Raybestos
1953 JET Brakes - Brake Hardware, Front
H403 Adjusting Screw Spring PG PLUS PREMIUM
Notes: 2 Per Car
H131 Brake Shoe Return Spring PG PLUS PREMIUM
Notes: 11'" Brake Drum
H131-2 Brake Shoe Return Spring PG PLUS PREMIUM
H132 Brake Shoe Return Spring PG PLUS PREMIUM
Notes: 10'" Brake Drum
H1107 Hold Down Pin PG PLUS PREMIUM
Notes: 4 Per Car
H1107-2 Hold Down Pin PG PLUS PREMIUM
Notes: 4 Per Car
H1150 Hold Down Spring PG PLUS PREMIUM
Notes: 2 Per Car
H1150-2 Hold Down Spring PG PLUS PREMIUM
Notes: 2 Per Car
Good Luck0 -
Please note, the above info does not apply to the brakes of the Hudson Jet. The Jet brakes are 9" - fronts 9" x 2" and rears 9" x 1 3/4", thickness .175". The brake equipment is of the Bendix self-centering floating shoe type. Only minor adjustment is required as the shoes center themselves when the brakes are applied assuring uniform brake lining wear. Eccentrics contact the brake shoe ribs to provide adjustment to compensate for lining wear. This is a completely different system from that used on the Hornet & Wasp vehicles.
Jerry
53jetman
HET Jet Tech Advisor0 -
53jetman wrote:Please note, the above info does not apply to the brakes of the Hudson Jet. The Jet brakes are 9" - fronts 9" x 2" and rears 9" x 1 3/4", thickness .175". The brake equipment is of the Bendix self-centering floating shoe type. Only minor adjustment is required as the shoes center themselves when the brakes are applied assuring uniform brake lining wear. Eccentrics contact the brake shoe ribs to provide adjustment to compensate for lining wear. This is a completely different system from that used on the Hornet & Wasp vehicles.
Jerry
53jetman
That makes sense. Any idea where I could locate part numbers for replacement springs and pins (Napa etc)?
Thanks to all who responded.
Matt0 -
Matt - I have not been able to locate new brake hardware for the Jet applications. Best source I've found are from Jet parts cars. The early Rambler & Willys Aero used the same brake system. I know this does not paqrticularly give us better odds at finding these parts, but it does widen availability somewhat.
Jerry
53jetman0 -
Jerry
53jetman
The infomation came from the Raybestos catalog which looks like they use the same infomation for all Hudsons. Too bad.0 -
Thanks again to all. I'll put him in touch with Barry S.
This should be enough to get a fellow Hudsonite going again.
Matt0 -
This is the information I have...
Front Brake Hose: NAPA/United # 11190 (Central Auto Parts #F57819)
Rear Brake Hose: NAPA/United # 5784
Brake Shoes (Front and Rear) 9x2 Part No. RS-51
Master Cylinder: Wagner Lockheed cast # F2796 / MC2796, Neihof K2796 (Same as 61-66 Jeep Dispatcher)
Master Cylinder Rebuild Kit: NAPA 137, Raybestos MK137, Neihof K11300, also from Clifford's at 909-734-3310
Front Wheel Cylinder Rebuild Kit: Wagner Lockheed #F71670
Front Wheel Cylinder: Wagner Lockheed 1 1/8 bore: Leftside #F15427 / Rightside #F15428
Wheel Seals, Front, Inner/Outer: Victor Seals 49466 and 134-9466
Rear Wheel Cylinder: F38926
Rear Wheel Cylinder: Wagner Lockheed 15/16 bore: NAPA United # 36028, Rebuild kit's NAPA #250 or Wagner #F136770 -
Any source for brake return springs?0
- 103 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
