Transmission Mount
Noboldy Has Them But K Gap0
NAPA has replacement Front Motor Mounts...Less than $15 each0
certain year AMC motor mounts work fine on step-down 6's too but they're square rather than round. K-gap has correct ones0
i have THE REPLACEMENT NUMBERS FOR THE front motor mounts...WHAT i AM LOOKING FOR is the rear Transmission Mount...I know about K gap and also they are available from Kantner, but they are a bit pricy compared to NAPA if I can find the rear mount there0
Tom:
I know you want to find the exact part number for a rear transmission mount... I do not have one... BUT... when searching for a transmission mount for a T-86 transmission... the same used in your WASP, lots of Fords, Jeeps and other cars I came up with what looks EXACTLY like the rear transmission mount I just changed in my 53 Wasp... same mount as your car.
http://www.4wd.com/shop/productdetail.asp?c=7&model=vintage&subcat=T86&division=3&category=255&productsku=939995
Mount pictures from that site... note rubber (item 25) is first picture and Poly is second picture. Both reasonably priced and maybe the elusive rear mount.
As with all MAYBEs, buyer takes the risk... but It looks very close to me... call them and ask if they know if it works on all T86s... my suspicion is yes.
Cheers0
