6 Volt alternator question
Hi everyone, I'm installing a 6 volt pos. ground alternator. I like keeping the car 6 volts but want to make that one change to an alternator. Which would be the best gauge to use in place of the light. Amp meter seems to be the obvious choice but how about using a volt meter? Thanks, Richie.
Richie wrote:Hi everyone, I'm installing a 6 volt pos. ground alternator. I like keeping the car 6 volts but want to make that one change to an alternator. Which would be the best gauge to use in place of the light. Amp meter seems to be the obvious choice but how about using a volt meter? Thanks, Richie.
Try the results of this search: http://www.classiccar.com/forums/search.php?searchid=189059
one of the threads ought to have what you need.0 -
I prefer voltmeters.0
I'm with Jim. Voltmeter hookup is much simpler and doesn't add to the voltage loss in the wiring, as an ammeter does.0
Thanks everyone, I appreciate all your opinions. Richie.0
- 114 Hudson 1916 - 1929
