Napa Numbers for Front wheel bearings
Unknown
Anyone got the NAPA part numbers for front bearings for a stepdown. I can't find my sheet with the numbers on. Need numbers for inner and outer bearing and cup.
Thanks
  • Richie
    Richie Senior Contributor
    Thanks
    What I have listed are as follows. Inner Timken cone 15123 cup15245, outer cone Timken 09067 cup 09195. Seal napa # 16246
  • Thanks got those matched up to NAPA numbers.
  • What are the NAPA numbers and current cost? (please)
  • Here are the NAPA Numbers I will let you check the price for you on NAPA online. I bought mine in Canada so prices are different.
    Inner Bearing
    BR15123 bearing
    BR15245 cup
    Outer Bearing
    BR09067 bearing
    BR09195 cup
    Seal NOS 15649
    All of these numbers are uptodate and show on the NAPA online catalogue. I took the numbers in they gave me the parts I fitted them and they are correct.
    Thank you. Two full sets ordered. One for placemetn now since the shop has the wheels off for a complete brake job, and a second for the Parts Vault.
  • I have a 57 hornet, will these number match up? If not would you please inform me or tell me where I can find that information.
  • bull_islander
    bull_islander Expert Adviser
    Don't forget to show your AAA card if you're a member. Saves 7% at NAPA.
  • Sorry I am clueless about 57's
  • Uncle Josh
    Uncle Josh Senior Contributor
    I'd write Paul Schuster, he's the tech advisor for the 567 group.
    hudson1957@aol.com
  • mars55
    mars55 Senior Contributor
    1955 - 1957 Hudson Hornet front wheel bearings.
    Inner Cone: BCA/National NAPA Timken LM67048
    Inner Cup: BCA/National NAPA Timken LM67010
    Outer Cone: BCA/National NAPA Timken LM11949
    Outer Cup: BCA/National NAPA Timken LM11910
    Inner Wheel Bearing Assembly (Cup and Cone): BCA/National A6, NAPA BR6
    Outer Wheel Bearing Assembly (Cup and Cone): BCA/National A2, NAPA BR2
    1955 - 1965 Fords use the same bearings. Some parts catalogs still list '55 - '57 Hudson wheel bearings, but not NAPA online.
