Napa Numbers for Front wheel bearings
51hornetA wrote:Anyone got the NAPA part numbers for front bearings for a stepdown. I can't find my sheet with the numbers on. Need numbers for inner and outer bearing and cup.
Thanks
What I have listed are as follows. Inner Timken cone 15123 cup15245, outer cone Timken 09067 cup 09195. Seal napa # 162460 -
Thanks got those matched up to NAPA numbers.0
What are the NAPA numbers and current cost? (please)0
Here are the NAPA Numbers I will let you check the price for you on NAPA online. I bought mine in Canada so prices are different.
Inner Bearing
BR15123 bearing
BR15245 cup
Outer Bearing
BR09067 bearing
BR09195 cup
Seal NOS 15649
All of these numbers are uptodate and show on the NAPA online catalogue. I took the numbers in they gave me the parts I fitted them and they are correct.0 -
51hornetA wrote:Here are the NAPA Numbers
Thank you. Two full sets ordered. One for placemetn now since the shop has the wheels off for a complete brake job, and a second for the Parts Vault.0 -
I have a 57 hornet, will these number match up? If not would you please inform me or tell me where I can find that information.0
Don't forget to show your AAA card if you're a member. Saves 7% at NAPA.0
Sorry I am clueless about 57's0
lucasclark wrote:I have a 57 hornet, will these number match up? If not would you please inform me or tell me where I can find that information.
I'd write Paul Schuster, he's the tech advisor for the 567 group.
hudson1957@aol.com0 -
1955 - 1957 Hudson Hornet front wheel bearings.
Inner Cone: BCA/National NAPA Timken LM67048
Inner Cup: BCA/National NAPA Timken LM67010
Outer Cone: BCA/National NAPA Timken LM11949
Outer Cup: BCA/National NAPA Timken LM11910
Inner Wheel Bearing Assembly (Cup and Cone): BCA/National A6, NAPA BR6
Outer Wheel Bearing Assembly (Cup and Cone): BCA/National A2, NAPA BR2
1955 - 1965 Fords use the same bearings. Some parts catalogs still list '55 - '57 Hudson wheel bearings, but not NAPA online.0
- 175 The Flathead Forum
- 602 Vehicles
