Speedometer compatability
I believe part of your problem with your speedometer readings is that your '46 speedometer head was designed to operate at 2000 turns per mile and your '53 Hydro & the hydro rear end is designed to operate a 1000 turns per mile speedometer head.0
Thank You Mars 55, That explains the reason its about half off the actual road speed0
A good speedometer shop can provide a little reduction or step-up gearbox to correct the reading. It goes on the tranny speedo cable fitting, then your cable goes into the box. Just tell them what correction ratio you need (2:1 step-up), and show them the bottom end of your speedo cable so they can provide the right connections for the box.0
Park,
Thank You for the Information....0 -
One of the JetSetters has to replace his speedo cable on his '54 JetLiner, the entire cable and sheath needs replacing, not just the inside cable. Do the Jets use the same as the larger Hudsons? Or perhaps someone can suggest a source for this part?0
- 115 Hudson 1916 - 1929
