how do you remove old running board rubber
bellbigdawg
bellbigdawg Expert Adviser
getting ready to do the running boards on my 41 bigboy, original rubber mats cracked and a few chunks missing, but seem to be glued on good. how do you get the old ones off??
  • Richard E.
    Richard E. Senior Contributor
    A hammer and a sharp wood chisel works real well!!
  • Took mine off the Terraplane with a flat sanding flap wheel on the grinder till I got close and took the last with a wire brush on the grinder. MESSY !! Did it outside with a resperator and eye goggles. Bud
  • A Little Heat On The Bottom Makes The Job Twice As Fast, Bill A
  • LanceB
    LanceB Senior Contributor
    I had no problem taking it off. I had the kids chip it off, :D
  • bellbigdawg
    thanks!! lots off tips here!! would soaking in kerosene or something help?? god this stuff is stuck on there!!
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    HI, if its held on by a contact adhesive, you can use a good hot air blower at a couple hundred degress + this will reactivate the glue or you could use acatate (nail polish remover) but you would have to be very careful of any single pack paint, its ok with 2 pack painters though
    we do this at work when we lay down laminates etc and they arnt straight enough
    Mike
