Carb question
I was just comparing the Carter sheets on the two - other than the flange size being different (749S is 1½; 990S is 1¼) the two are virtually identical as far as specifications.
If you'd like I can scan the 990S sheet (I've already done the -749S) and send them to you via email.
Drop me an email.
Alex Burr
HudsonTech
Memphis, TN
NEChudsontech09@yahoo.com (Drop the NEC)0 -
hudsontech wrote:I was just comparing the Carter sheets on the two - other than the flange size being different (749S is 1½; 990S is 1¼) the two are virtually identical as far as specifications.
Drop me an email.
Alex Burr
HudsonTech
Memphis, TN
Alex that would be great, I'll send you a PM.0
