Fabulous Hudson Hornet Decals
The Fabulous Hudson Hornet lettering that you see on my car above was hand painted on. Most, if not all, of the lettering on all the original racing Hudsons were painted on by hand. If you have seen a smaller decal you can disregard any of what I have said.0
You can take a picture of Marshall Teague's Fabulous Hudson Hornet to most modern Sign & Graphic Shops to scan and scale to fit your car. I had high Image Vinal Graphic 'Magnetic' Fabulous Hudson Hornet signs made for my '53 Hornet Coupe to install on special ocassions.
I used Grahic Details Sign Shop in Erie ( graphicdetails@verizon.net ) who will mail order either large Vinal Graphic Decals or Magnets. They use High Image as well as reflective Materials.
Normally I put Fabulous on the fender. The #37 was a special photo Op. Being Magnetic they can go anywhere.0 -
I do vinyl sign work and a friend of mine is looking for a less permanent way to make it look like the fab hudson hornet so he can remove after some use.0
