Coupe door parts needed
Working on a new project...'51 C8 Coupe. Somewhere along the way, somebody disassembled the driver's door and the parts got separated from the car. I need the interior window frame, the metal trim panel that is at the top of the door panels and a window regulator (not the vent window regulator). Thanks everybody!
tristansdaz wrote:Working on a new project...'51 C8 Coupe. Somewhere along the way, somebody disassembled the driver's door and the parts got separated from the car. I need the interior window frame, the metal trim panel that is at the top of the door panels and a window regulator (not the vent window regulator). Thanks everybody!
Sent you a PM.
No Parts, unless a sedan regulator will work, I need other info.0 -
tristansdaz wrote:
Are you referring to the 1 inch stainless trim on the door panel top?? Walt.Working on a new project...'51 C8 Coupe. Somewhere along the way, somebody disassembled the driver's door and the parts got separated from the car. I need the interior window frame, the metal trim panel that is at the top of the door panels and a window regulator (not the vent window regulator). Thanks everybody!0 -
walt's garage-53 wrote:Are you referring to the 1 inch stainless trim on the door panel top?? Walt.
No, this is the 4" piece of metal just below the window frame that is simulated woodgrain on the Hornets and Commodores. Thanks.0 -
Try these folks. Fast friendly service:
Large stock of NOS and Used Hudson Parts: Ken Amman, 240 Raleigh Pl., Lennon, MI 48449 (810) 621-3665. NOS and used parts and some cars for sale.
e-mail:
kamman@power-net.net0 -
Ken Amman sold out to Bill & Charlies Antique Auto, 10917 Commercial St., Richmond IL 60071 - Phone (815) 678-AUTO & fax (815) 678-7776
Jerry
53jetman0 -
I've got a trim panel that you need. Just the driver door or a whole set?0
RL Chilton wrote:I've got a trim panel that you need. Just the driver door or a whole set?
Hudzilla says that he has the parts I need, have been in contact. However, if he doesn't have the correct upper trim panel (valance?), I'll be in contact. I only need the one for the driver's door. Thanks for your reply.
Larry0 -
I am looking for 2 plates that hold the shafts and bearings clamped together with a countersunk stovebolt for a 54 Hornet Hollywood side window. Merry Christmas and Happy New Year
Thanks for everybodys help this past year . duncan0
