700R4 Stepdown installation mods?
Has anyone installed one of these overdrive transmissions?0
Hello,
I have not installed any GM OD Transmissions, only a Turbo 350 in a '37, a Hydro in a '47 and a Turbo 400 in a '51 Hudson. The 700R4 is a very large Trans, maybe little larger than a Turbo 400. Maybe this info will help out proceding...
In all installations I 'altered' the rear crossmember by fabricated mounts up to the center 'Adapter' Plate because I didnt like the long heavy Hornet motor & trans assy resting only on the tailshaft mount. It probably would be okay to utilize the rear mount though...
The '51 I moved the motor way back cut out the middle of the crossmember then fabricated brkts rearward on each side. (The '51 is a Strip Car )0
- 115 Hudson 1916 - 1929
