Window crank
Edwardjohnsr
I want to remove the inner panel on my Hornet sedan front door. I have the vent wing handle off but need advice on the window crank and the door handle. Does the window crank have a standard c-clip attachment? What about the door handle. How does it come off?
Thanks in advance.
Ed
Thanks in advance.
Ed
the door handle has a cheese head screw, and the window crank is pinned.
for the door just remove the screw (philips) and the handle will slide off
for the window crank, compress the panel and escussion twoards the outside of the car. you will find a cross pin that you can force out with an awl. can't remember if its parallel or perperdicular to the crank0 -
Thanks Nick. Sounds easy.
Ed0
