27 Hudson body parts
One thing you might want to do right away, would be to join the H-E-T Club so you can begin to plug into the parts and technical advice network. http://www.hudsonclub.org/ . You should find also others with '27's so you'll can milk them for advice (the Club roster lists all 3500 members' cars, so it's a matter of going through the roster when it arrives).0
What do you mean by "door parts"?
Geoff.0 -
Don't have parts, but do have Mechanical Specification sheets for 1927 - drop me an email at HEThester_nec @yahoo.com (drop the HET) and I can email them back to you.
Alex B0 -
I have mailed my check to join, though I am sure that it has not had time to arrive yet. Thanks for the info, and will be waiting for the list.
Blackie0 -
Across the top of each door, and running down both sides of the window is a trim piece. I am in need of three of these. They seem to fit either the front or back door. At the bottom of each window is a piece that goes across. It holds the upholstery in place, and has a 'seal' attached that goes against the window. I am in need of three of these. Also needed, an inside door handle.0
Oaky, another question - is this a standard steel bodied Hudson sedan? I have spare '28 and '29 versions of the parts you need, but they are probably different specs from the '27. You would need to provide measurements.
Geoff.0
