35 Terraplane cutout relay
35 Terraplane
35 Terraplane Senior Contributor
Does anyone have a source for the charging circuit "cutout relay" or "circuit breaker" for a 1935 Terraplane Special. I found a copy of the original owner's manual which shows a charging circuit marked "without regulator". The diagram shows a circuit breaker. This is the part I need.
  • mars55
    mars55 Senior Contributor
    I don't know where you get a cutout relay for a Terraplane. But I believe that one from a Ford Model A would work since all it does is open the points if the current reverses though the cutout relay. That is the battery tries to charge the generator.
    http://www.snydersantiqueauto.com/5030
  • tigermoth
    tigermoth Expert Adviser
    call Sammy at northwestern auto supply in grand rapids, mi. their website also has a part search form. sammy is a great guy. my cut out on my '35 is an auto lite, but i do not see a part #. regards, tp
  • Park_W
    Park_W Senior Contributor
    Pro Antique Auto Parts in CT has them. (860) 623-8274 or http://www.proantiqueauto.com/.
  • 35 Terraplane
    TP, When your car is running does the tell-tale light on the dash remain lighted?
    Tom
  • Park_W
    tjfxmk, it you're running the simple cutout relay, you can connect that tele-light wire to the terminal on the cutout where the generator output wire goes, and the light will work OK.
