52 Hudson 6 volt part numbers
Hello Im new member of the Hudson Club.I purchased a 1952 Hudson Hornet 2 door.We are going through the car making sure it road trip worthy.Im working on the front turn signals,running light bulbs and rear license plate buld.They are so old we cannot see any part number.dose anyone know proper number for these bulbs.Thanks Phill
Phill
Look In Your Owners Manual All The Bulb # Are In There And You Can Get Bulbs At Your Lopcal Parts Store0 -
I do not have a owners or shop manual for this car.Thanks Phill0
:cool:
Phil the following is what you need.... will be putting this on my website next update... Cheers from HOT;)1952 Hudson Hornet wrote:Hello Im new member of the Hudson Club.I purchased a 1952 Hudson Hornet 2 door.We are going through the car making sure it road trip worthy.Im working on the front turn signals,running light bulbs and rear license plate buld.They are so old we cannot see any part number.dose anyone know proper number for these bulbs.Thanks Phill
MAZDA bulb number application
44 Radio and Hi Beam indicator
51 Hydra Trans shift indicator dial
55 tell tale, glove box, signal indicator,
clock, speedometer and instrument lamps
63 Parking and License Lamp
81 Dome Lamp - top bow lamp Convert
87 Dome and Courtesy Lamp
1133 Back Lamps
1154 Park Tail and stop lights
4015 Fog Light seal beam
4030 Three prong Head lamp bulb 45/35 Watt
4535 Spot Light Seal Beam0 -
NAPA and O'Reilly Bulbs.
The lower Mazda numbers are good at NAPA and O'Reilly's for their house brands Not familiar with backup and fog lights and their numbers. If the rear turn signals use a separate bulb as was case in '51, use an 1129. Walt0 -
Phil, I'm e-mailing you a list of all the bulb numbers in a '52.0
Thanks all for help,Hudsons number one, Thanks again Phill0
- 111 Hudson 1916 - 1929
