distributer hold down wont work
First make sure the gear and shaft length are correct, if they are you are not getting the distributor gear to mesh with the cam gear, wiggle with light pressure on the top.0
A sad note: I had the same problem with a Mallory on a FE Block where I used an Edelbrock Intake. The hole for the disruptor was .35 inch off of the stock intake location. Are you using the stock intake?0
- 115 Hudson 1916 - 1929
