Vibration in 51 Hornet low RPM gearing down
HornetSpecial
Have a vibration when I slow down and transmission down shifts to low gear. Does not seem to vibrate as you take off and go through gears c
hange. Any guesses?? Help !!
Paul
Paul
It's probably the rubber bushings with the vulcanized threaded portion broken off at the u-joint cradle0
I suppose they're not bushings (don't know what else to call'm)----they have threaded parts at each end of the rubber.0
Thats what I also suspect. Maybe others have a differant guess. Thanks for your input.
Paul0 -
usually when those mounts are bad, you get a thump from the driveshaft hitting the floor on acceleration0
Thanks Nick !! I don't seem to hear any thumping going on. May that's next. I guess I will have to visually inspect drive shift bushings.
regards, paul0 -
I think rpmonroe's estimatation is correct without further info. Another question I have to ask is, have you recently replaced the transmission mount?
Modern reproductions have too hard of a rubber pad on them and Hudsons will have a bad "clunk" when downshifting to 1st. Usually there is not much of a vibration, just the hard downshift. Best to go with an NOS or good used tranny mount, as the original rubber is much softer than modern vulcanized material.0 -
Hi Russel,
It has had the tranny done just before I got it. That is very interesting about rubber. It does shift a little hard on down shift. You learn more stuff on this forum. Thanks guy,s !:rolleyes:
Paul0 -
Two things to check for a harsh 2-1 coast downshift. 1) Is the engine idle speed set correctly? too fast will cause a clunk. 2) Is the throttle pressure and carb linkage set according to the shop manual?, Too much throttle pressure can cause harsh coast downshifts. Just a couple things to try. Lou Cote0
Thanks Lou !! I will reset the linkage corectly.
Paul0
- 115 Hudson 1916 - 1929
