Here's a dumb question re brake cylinder removal
Paul most wheel cylinders are comprise the components shown in the attached image. The rebuild kits will contain all components except the two pistons that are located behind the external rubber covers. I use a brass drift and tap on one of the Pistons to drive stuck components out of the cylinder.0
Thanks Ken,The pistons in my cylinder are toast as well (is that an English expression I wonder; by it I mean they aren't in good condition).Looking at what I have to work with I'm not even sure that honing the cylinder will help0
Paul Disconnect the brake line from wheel cyl.. Remove two bolts holding wheel cylinder to backing plate. Wheel cylinders tend to get stuck to backing plate over time. Tap wheel cylinder with hammer it will loosen. On some cars the bleeder valve also need to be removed. Might as well remove it anyway to clean crud out of wheel cylinder. If the wheel cylinders are pitted I suggest replacing them. Lee O'Dell0
Folks like Larry Cramer will know if there is a replacement part number for your cylinders.0
Thanks Lee ; next job on the listKen,That is looking very much like the way forward.Today was a good day weather wise over here so I decided to try and free up the rear wheels which were stuck solid after standing so long. Like most things the initial "I'll just do this" kind of expanded a little0
Paul, if wheel cylinders are as bad as you say, it is a good chance the master cylinder is in similar condition. It would be wise to check it out as well and replace all old brake hoses as well. Brake hoses deteriorate from the inside out. Also, if the steel brake lines have never been replace you might consider replacing them as well. They do rust also. On the 47 PU I bought I had to replace the rusty brake lines because of leaking after replacing wheel cylinders, master cylinder and hoses. Keep up the good work Paul. Lee O'Dell0
Thanks Lee,Good advice. I think it's a complete overhaul. Last time I drove it (6 years ago) the brakes weren't that great however with the mechanical assist they were good enough to pass inspection but 6 years of not doing much isn't going to have helped them.0
Paul, your mention of secondary mechanical brake assist reminded me when I bought my 52 Hornet in Las Vegas and drove it home to Burbank, Ca 275 miles. The mechanical system worked so good I didn't realized only the rear brakes were stopping the car. When I got home I did a check of master cylinder for fluid. and the master cylinder was bone dry because of rusted through brake line. I replace the complete brake system. It can be a life saver to make sure the secondary mechanical brake assist is adjusted properly. This was my first experience driving a Hudson and I was not aware any car had secondary mechanical brake assist. That sold me on having such a back up braking system should hydrolic brakes system fail. I have wondered since why Chevy, Ford, Chrysler and all the others did not have this. Hand brakes are about useless to stop a car. A secondary brake system sure would have kept me from going through a chain link fence when the master cylinder failed on my El Camino if it had such a system like Hudson had. Just passing on some memorable and scary experiences. Lee O'Dell0
Don't monkey with trying to hone and re-build. New ones are less than 15 bucks in most cases, and the rebuild kit will cost you 10..
What year/model are you working on. Pre-stepdown are different than stepdown, and pacemaker stepdowns are different than the others. Pre stepdown eight cylinder and trucks are different than sixes, and rights are different than lefts.
Master cylinders are readily available at NAPA Again, pre-stepdown's are different than stepdown.
I have all the part numbers. HETcramerlp@roadrunner.com (drop the HET) or you can post what you're working on here and I'll respond. Larry Cramer aka Uncle Josh
Thanks Larry,It's a 1939 Hudson 112. $15 would be a good price as I'd need to get them shipped to the UK as well.I'd already decided that rehoning probably wasn't the best way forward tbh.0
OK, Just checked these out and updated my spreadsheet. For some reason I didn't have the 36 to 40s listed.
The only difference on the 36 to 47s are the size of the thread, for hose or steel line. If you could find an adapter at NAPA it would standardize them. The are all available on Amazon, ebay or Rockauto.
Wheel cylinder
Coni-Seal
WC13221
48-54 Hudson RF
1 1/8 in
Wheel cylinder
Coni-Seal
WC13220
48-54 Hudson LF
1 1/8 in
Wheel cylinder
Coni-Seal
WC13601
40-54 Hudson RR
15/16 in
Wheel cylinder
Coni-Seal
WC13600
40-54 Hudson LR
15/16 in
Wheel cylinder
Wagner
WC78975
36-47 Hudson RR
1 in
Wheel cylinder
Wagner
WC78974
36-47 Hudson LR
1 in
Wheel cylinder
Wagner
WC9336
36-47 Hudson LF
1 in
Wheel cylinder
OK, I had them misfiled
Wagner
WC9337
36-47 Hudson RF
1 in
Thanks Larry; a great help and reasonable price at Rockauto as well.One question ; WC78974 and WC78975. You have both as RR; I presume one is LR?0
BTW, master cylinders are listed here
Brake Master Cylinder
Napa-United
36-47
4360
Napa-United
48-54
3081
Napa-United
Jet
2796
Hi Paul. Be careful that they match your brake shoes. Brake shoes for 39 112's had a unique slotted fitting to the cylinders as opposed to the more common pins. You might need to salvage these from the old cylinders for use on new ones.0
Thanks for that; I need to do some more research before I take the plunge. Being in the UK I can't wander back to my local NAPA unfortunately and get something replaced0
Thanks Paul. Typical graphic error. I fixed it. I haven't tried to put 'em both on the same side...yet.0
And I see from the manual that a Pacemaker uses 1 1/16 cylinders on the front, since the shoes are 1 3/4. The rest of the stepdowns standardized on the 2 1/4 shoe in the front.
BTW, Dave Konstansik is relining shoes for $50 an axle
On my 36 with the cam adjuster on the secondary, I got 47 shoes which both Auto Zone and Advance listed but not 36, and drilled a hole for the cam adjuster.
Be careful that they are "High Anchor Pin" shoes. I have been sold a few sets (for '47 six) that look like Hudson shoes but were for Ford (and possibly others) that were standard anchor pin location. If in doubt, have your shoes relined, emphasizing that you want your shoes back. I learned this one the hard way. If you want the brakes to actually work when you are done, you should also have the shoes arced to match the drum before installation.
Just my two bits worth. Frank
Okay ; next question and I may need some help. I have sourced the wheel cylinders via Rockauto and they work out at a great price even being shipped to the UK; price worked out at about $80 for all 4.Now I need a master cylinder and am struggling to find one; I see ones advertised on eBay for around $65 but have no visibility of how good or otherwise they are.Larry,I have tried searching using the part number you quoted above but with no luck so any chance you (or someone) could point me at an actual master cylinder I could look at all please?Thanks again for all the great help; really appreciatedI have found someone local to me who'll reline the shoes for around £40 ($60) per axle which I thought was a good deal0
Paul, alternative is to re-line you own cylinder with stainless steel. NOS ones seem to come up regualrly on ebay.Geoff0
I echo, Replace Cyl's rather than Hone....
This is a 36//7 3 bolt master cylinder, I believe the same item was used in 38/9 and they were also used in Fords of that era.
Thanks all,Kenneth ; that's the one I was after so has been added to my cart waiting for payday to hit!0
Looking at the drawings in the workshop manual, the 36 shows a hydraulic stoplight switch in the brake line down near the LH rear wheel.I can't see from the 38/9 drawing the location of the stoplight switch but it does show only a single brake line coming from the master cylinder and their is a 4 way union near the front LH wheel.These are drawings for LHD cars of course, Paul's may have a different arrangement.The master cylinder and banjo in my photo is one that I'm fitting to a 35, I'm using the step-down arrangement with a stop switch at the master cylinder.0
The couple of Oz 39's I've seen have a mechanical switch (and so do the 46's) The center fitting out the end is feeding the rear brake line and the 2 out of the "Y" feed each front wheel. The 46 is different in that respect. Ken U-Tx, I'd like to buy a set. They don't survive well if any cross threading occurs fitting the hard lines. My email is HETghebblethwaite@hotmail.com. (Leave out the HET) Thanks0
I have a forwarding address in Portland OR which should work better for us.0
At the risk of hijacking this thread, PayPal OK? OR email me with further details as above.0
Glenn,How does the forwarding address work? Is that just a friend you have that can package things up for you or is it something more sophisicated?0
Paul, I use shipito.com from time to time for stuff from the US. Its a good option for larger and/or heavier items that don't fit into flat rate USPS boxes. Or for the odd recalcitrant that "don't post nuffin to no foreign countries".0
Thanks Bob,I'll investigate that option as well0
