1933 Essex water pump rebuild
on my recently purchased ‘33 Essex it appears the water pump is leaking a bit. I realize there could be a lot of variables that cannot be known until you open the pump up, but in general, if it is leaking, how difficult are they to rebuild?
regards, Tom
They have packing. If the shaft is not heavily scored, you can just replace the packing and snug it up. If it really needs rebuilding, I believe Jeremy Burris can do it for you.
Thank you.
Is there ever a “just another 1/4 turn after the break-in mileage” ? The thing looks pretty, but so did the starter and the beauty was only skin deep on that.
regards, Tom
if I should need it, does anyone have Jeremy Burris’ contact information?
regards, Tom
It's in the roster. He lives in Kentucky.
He also has an ad in the WTN with contact info.
Great! Thank you.
regards, Tom
Pump appears to have little use since rebuild so a VERY slight turn of the packing nut stopped the leak. The fan still turns freely.
regards, Tom
