Timeing Cover Seal
You can get a speedi-sleeve that fits right over this, and gives you a new surface. they are a very thin stainless sleeve, with an applicator ring. You punch the sleeve on, then peel the applicator ring off. Any good bearing shop should be able to get these for you.
Geoff.0 -
A machine shop will turn up a new one for a few dollars. The stainless steel sleeves are a good idea. I fitted one recently on the diff pinion shaft. The seal was leaking due to bad corrosion and wear. Regards, Barry0
We have them in stock. $18.00 & postage. Can send out one today if you call. 309-267-6158. Randy Maas P.O. Box 589 Manito, Il. 615460
Randy,I sent you a PM , Thanks Rudy0
maasfh wrote:We have them in stock. $18.00 & postage. Can send out one today if you call. 309-267-6158. Randy Maas P.O. Box 589 Manito, Il. 61546
Called Randy and he has one on the way. Check is on the way Randy . Thanks to all. BUD0 -
Sounds like more satisfied Hudson owner/drivers soon to be on the road again. Dont you wish ever thing went that smooth. Thanks to all helping. Bob0
