1935 Hudson engine hood hinge.
on my '35 t-plane they used identical part number "U" shaped chromed brackets with a countersunk macine screw on either side of the hinge. the screw went through the bracket and lip on the front side of the cowl, with a nut and washer to attach. tom0
should read "machine screw"...vice "macine screw" ...sorry0
John, if you require photo's of the parts - private email me at [email="1934hudson@charter.net."]1934hudson@charter.net.[/email] I just received these parts back from the plater so, before I install them on my 34H can email you a couple pix! Jim0
Has anyone removed the lock mechanism from glovebox 2 locksmiths have tried and failed0
