Clutch and Transmission Work!!!!!
I got enough stuff re-attached today that I was able to start the Pacemaker and see if I had the clutch and transmission installed properly.
They work!!!!!! I am able to shift through all the gears just fine. I will have to adjust the clutch pedal (still do not have the main spring on yet) as I get a little grinding going into reverse. But then maybe attaaching the drive shaft to the output shaft will help that.
My goal is to get enough re-assembled to be able to drive it on the trailer when the Army moves us in three weeks back to Fort Leonard Wood (Route 66, here I come).
Hudson308 wrote:
I was not aware that the Pacemaker and LWB "R" type transmissions were different. But this happens to be the original gear box for the car.Congratulations!
The grinding problem may also be a simple adjustment of the shift linkage rod... especially if the grinding happens in 2nd, as well.
On the off chance you swapped in the tranny from a long-wheelbase car, you're probably already aware that the single shift lever on the transmission itself is different on the Pacemaker vs. the LWB cars. The "clocking" of the double-D mounting hole is different to allow for the different shift rod length/position.0 -
Congratulations! It's always great when a plan comes together.:)
Where's Fort Leonard Wood?0 -
RL Chilton wrote:
I-44 West/South West out of St. Louis, towards Springfield, MO and Tulsa, OK.Congratulations! It's always great when a plan comes together.:)
Home of the Engineener, Chemical and Military Police Schools, Basic Training and a few other schools for Enlisted and Officers.0 -
Hudson308 wrote:The differences were all external (bolt-ons), unless Hudson offered some special Pacemaker-only 1st and 2nd gear ratios. Clutch diameter and the aforementioned shift lever are the two things I noticed were different. I learned about the latter when bolting a '51 Pacemaker overdrive trans into my '49 Super 6. The Pacemaker trans also had a strange right-angle gear reducer for the speedo cable, but I think Hudson did that on a few models for a little while in '51.
My speedo cable goes into the factory OD Unit at a right angle also, drivers side, opposit the OD govenor.0 -
Pacemaker500 wrote:
When you get to Fort Leonard Wood, let me know I have something for you to check out in the neighborhoodMy goal is to get enough re-assembled to be able to drive it on the trailer when the Army moves us in three weeks back to Fort Leonard Wood (Route 66, here I come).0
