Compression
Does it go up with a few squirts of oil in the cylinders? (ring leak) or not (valve leak)?
Sounds a little low to me but they're even which is good.0 -
The readings you have would be about right for a cold motor, however you should really check them hot to get a reliable reading. The starter motor is a reduction drive, so the engine swings over really slow.
Geoff.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
